Setting offset symbol values at once?
1622
06-07-2016 11:13 AM
AlexCarter
I'm glad that ESRI has added a way to use a field to set the offset of symbol/picture markers.  Does anyone know of a workaround to set all of the symbols offsets to a field at once?  You can set rotation and size, but not offset. Going through and manually changing each symbols X and Y offset to a field is very time consuming when you are dealing with a lot of symbols.
I know you can merge and set the offsets all at once, but that destroys the symbology already built.
Alex
