I downloaded the sample code from git. I want to implement the "Routing Sample Code" in my android application. However, I would first like to see how the Routing sample code runs on its own. Are there any tutorials on how to make it run, imediately after
3148
06-07-2016 08:50 AM
ThomasSaldana
How to run the "Routing" sample code on Esris, Android Developers Website
AlexanderNohe1
Honored Contributor
From the GitHub Page:
Run a sample
You should now be able to run any of the included samples. We will use the HelloWorld Sample as an example.
  • Select HelloWorld from the Select Run/Debug Configuration drop down
  • Click the Run button
Just select in the dropdown, routing and press play.
GitHub - Esri/arcgis-runtime-samples-android: ArcGIS Runtime SDK for Android Samples
AlexanderNohe1
Honored Contributor
Run a sample
AlexanderNohe1
Honored Contributor
Hey Thomas Saldana​,
I see you marked my comment as helpful.  Did this resolve the issue you were having?
