How to concatenate 'str' and 'int' objects with python
4136
06-06-2016 10:33 PM
AndrewNeedham
New Contributor III
Hi All,
I'm trying in a GDB using Arc10.2 to run a field calculate, into a text field using: "!SHAPE.firstpoint.X! &" "& !SHAPE.firstpoint.Y!" (without quotes) but this gives an error: 00539
  • cannot concatenate 'str' and 'int' objects
What would be the correct syntax?
I believe I need to cast but not sure how.
So far my workaround is to create a StartX and StartY field then combine them into another field StartXY, but this can be time consuming with a large number of records. There should be a better way.
!SHAPE.firstpoint.X! = 534792.9044
!SHAPE.firstpoint.Y! = 6917050.0155
End result should look like this:
534792.9044 6917050.0155
Cheers
FC_Basson
MVP Regular Contributor
Try this:
str(!SHAPE.firstpoint.X!) + " " + str(!SHAPE.firstpoint.Y!)
FC_Basson
Try this:
AndrewNeedham
New Contributor III
Thanks for that
