unable to connect to local or remote database using arcpy tools ( ImportXMLWorkspaceDocument, EnableAttachments_management, Append_management)
3199
06-06-2016 07:48 AM
RhondaGregory
I am trying to automate the migration of data using geoprocessing tools.  So I am starting with an XML Workspace Document that I exported using ArcCatalog.  When I try to import this into a new geodatabase, I tried dragging the db connection in ArcCatalog into the geoprocessing tool (ImportXMLWorkspaceDocument) and it fails saying 'Cannot access local or remote database'.
This happens with multple tools, i.e., EnableAttachments_management, Append_management and ImportXMLWorkspaceDocument)
Any help would be appreciated!
RhondaGregory
So the bottom line, the export XML workspace document had reference to the old schema and would not work.  I replaced the reference to the schema with a token and my python scripts now replace that token with the correct target schema
