QueryTask too long
3910
06-02-2016 08:07 AM
FlorianCADOZ
Hello everyone,
I have a problem with a query that returns me an error saying that the request is too long (error 404.15).
The error is returned by IIS (my web server) and after some internet research I found two parameters to change in IIS but nothing change.
So, I think that it's possible that the problem comes from arcgis server ...
If someone has an idea to solve this problem ... : /
RobertScheitlin__GISP
Florian,
  It fix this type of issue you setup a proxy to handle long query strings:
Setting up a proxy with Web AppBuilder Developer Edition | Support Services Blog
Setting up a Proxy | Support Services Blog
FlorianCADOZ
Hello Robert,
We've already got a proxy installed and working on (mainly for Authentication) but it's not the esri's proxy specified...
How should I proceed to make it ? Working with two proxy ? Only one of them but witch one ? etc.
Thank you in advance for your help
Florain,
  You should only use one. The esri one I linked to handles the long query strings automatically. But I do not know if it will does the authentication that you need or not. It does authentication but I am not sure what your does differently.
