Client id required to use if I am using ARCGIS JavaScript API & base map service?
2842
06-01-2016 03:47 AM
SangatiShinde
I am new in developing application using ARCGIS JavaScript API.
I am simply using ARCGIS JavaScript API and online base map  service in my web application.
Do I need to use client id if in JavaScript code?
I ask client to purchase developer licence for production environment.
After deploying application on production do I need to specify the Client ID in JavaScript API using OAuth authentication?
or no need to do anything for authentication?
Sangati Sanjay Shinde.
RobertScheitlin__GISP
Sangati,
  There is no need for oauth if your web map is public. If your web map is restricted to a certain group then you will need to login to the identity manager when challenged or use oauth to authenticate the app.
