Multipath pointcount seems to skip number one
2218
05-31-2016 02:30 AM
by Anonymous User
Not applicable
Can anyone else verify this and is it expected behaviour for some reason or possibly a bug?
When creating a multipath object (e.g. a Polyline or a Polygon), the pointcount seems to skip from 0 to 2 without registering the first point.
E.g. I'm drawing a feature by capturing mouse clicks on screen, the empty Polyline json might look like this:
{"paths":[],"spatialReference":{"latestWkid":3857,"wkid":102100}}
Then I click once, and the json stays exactly the same, and the pointcount remains at zero, although that first click *is* stored in the object. Because, then when I click a second time, the json jumps to something like:
{"paths":[[[3944884.454986632,6214117.358888438],[12586059.927814495,5838414.077461138]]],"spatialReference":{"latestWkid":3857,"wkid":102100}}
and the pointcount jumps to 2.
A polygon exhibits similar behaviour.
I discovered this while trying to implement a simple "if pointcount is zero then startpath else lineto" logic. I can get around it easily enough with a separate bool property, something like isFirstPoint and manually set it, but it just seems like something isn't catching that first point properly.
Cheers,
-Paul
nakulmanocha
Hi Paul,
Ok, I can see what you are referring to here.
Remember paths or rings cannot have just one point. In order to have a legit polyline it must have atleast two points which means path has to have 2 points or more. Same for polygons.
If you want to check for the PointCount use MultiPoint approach. See the code below. This way I get the desired results
// No points yet
qml: {"points":[]}
qml: Point count is 0
qml: {"paths":[]}
// First point added
qml: {"points":[[-4207876.484103985,3465221.995640751]],"spatialReference":{"latestWkid":3857,"wkid":102100}}
qml: Point count is 1
qml: {"paths":[],"spatialReference":{"latestWkid":3857,"wkid":102100}}
// Next point added
qml: {"points":[[-4207876.484103985,3465221.995640751],[1903563.1713803783,5368785.167021126]],"spatialReference":{"latestWkid":3857,"wkid":102100}}
qml: Point count is 2
qml: {"paths":[[[-4207876.484103985,3465221.995640751],[1903563.1713803783,5368785.167021126]]],"spatialReference":{"latestWkid":3857,"wkid":102100}}
Does this help?
Nakul
onMouseClicked: {
            if (capturePoints == true) {
                if (numberOfClicks == 0) {
// No points yet
                    console.log(JSON.stringify(points.json))
                     console.log("Point count is ",points.pointCount)
                    console.log(JSON.stringify(featurePoly.json))
                    featurePoly.startPath(mouse.mapPoint)
                    points.add(mouse.mapPoint)
                    pointGraphic.geometry = points
                    pointGraphic.symbol = markerSymbol
                } else {
// Next point added
                    featurePoly.lineTo(mouse.mapPoint)
                    graphic.geometry = featurePoly
                    graphic.symbol = lineSym
                numberOfClicks++
 Graphic {
        MultiPoint {
            spatialReference: {
                "latestWkid": 3857,
                        "wkid": 102100
 Polyline {
            spatialReference: {
                "latestWkid": 3857,
                        "wkid": 102100
