ArcGIS Pro Crashes When Adding Secured Web Map
3640
05-31-2016 02:11 PM
NilsBabel
Is it possible to add a web map with a secured feature service to ArcGIS Pro?  The credentials to the feature service are embedded in the web map.  When I click "Add and Open"  in the Project - Portal view Pro crashes and I get the send a message to Esri screen.  This doesn't happen on web maps with unsecured feature services.  Is this a bug or am I the only one having this issue?  I'm using ArcGIS Pro 1.2 and Windows 7 professional 64-bit.
JeremyWright
Hi Nils,
The team responsible would like to take a look at your repro case, if possible.  Have you sent it in via support?
Regards,
Jeremy W.
NilsBabel
No, I haven't.  Should I log a bug?
JeremyWright
I would recommend sending it in, so we can get it in the pipeline.
NilsBabel
Actually, it looks like I don't have permissions to start a new case on the support site.  Is there somewhere else I can log it?
