Is there a better way of getting that geometry into the second query? Not happy with line 28
from __future__ import print_function from arcrest.ags import FeatureLayer import arcpy import json if __name__ == "__main__": arcpy.env.overwriteOutput = True lgaUrl = "http://services.thelist.tas.gov.au/arcgis/rest/services/Public/CadastreAndAdministrative/MapServer/4" flLGA = FeatureLayer( url=lgaUrl) lgaWhereClause = "NAME = 'Launceston'" outSR = '28355' ## outFC="C:\Scripts\data.gdb\LGA" ## # get lga geometry ## lgaGeom = flLGA.query(where=lgaWhereClause,out_fields='shape',returnGeometry=True,returnFeatureClass=True,out_fc=outFC,outSR=outSR) lgaGeom = flLGA.query(where=lgaWhereClause,out_fields='shape',returnGeometry=True,outSR=outSR) geomText = lgaGeom.toJSON geomRings = json.loads(geomText) for key, value in geomRings.iteritems(): if key == 'features': features = str(value) features = features.replace("[{u'geometry': ","").replace(", u'attributes': {}}]","").replace("{u'rings':","{'rings':") # change to Crown Licenses crownUrl = "http://services.thelist.tas.gov.au/arcgis/rest/services/Public/CadastreAndAdministrative/MapServer/3" flCrown = FeatureLayer( url=crownUrl) crownWhereClause = "1=1" outFC="C:\Scripts\data.gdb\CrownLicenses" geometryType = "esriGeometryPolygon" # get crownLicenses crownLicenses =
38.
flCrown.query(where=crownWhereClause,geometry=features,out_fields='objectid,pid,shape',returnGeometry=Tr
e,returnFeatureClass=True,out_fc=outFC,geometryType=geometryType,inSR=outSR,outSR=outSR)
Solved! Go to Solution.
Try this:
import arcrest
fl_url = "https://site.com/arcgis/rest/services/reference/adminboundaries/FeatureServer/0"
token_url = "https://site.com/arcgis/admin/generateToken"
org_url="https://site.com/arcgis"
username = "admin"
pw = "some password"
where = "ISO_CC = 'US'"
sh = arcrest.AGSTokenSecurityHandler(username=username,
password=pw,
org_url=org_url,
token_url=token_url)
fl = arcrest.ags.FeatureLayer(url=fl_url,securityHandler=sh)
fs = fl.query(where=where)
print ("Found %s features with the where clause: %s" % (len(fs), where) )
if len(fs.features) > 0:
feature = fs.features[0]
geom = feature.geometry
geomFilter = arcrest.filters.GeometryFilter(geomObject=geom)
result = fl.query(where=where, geomtryFilter=geomFilter, as_json=True) # set as_json=False for the featureset object
print ("Found %s features with the where clause: %s and geometry filter" % (len(result['features']), where) )
Have you inquired about this at the ArcREST GitHub site? If so, what was the response? If not, it might be worth asking there as well while you wait for feedback here.
Try this:
import arcrest
username = "admin"
password=pw,
org_url=org_url,
