Refresh Database Connection in modelbuilder or python
4111
05-26-2016 01:10 PM
SharonZastre
I have created a model that will select features in an enterprise db and export to a dbf table.  This feature class is versioned and when edited, the updated data is not automatically recognized when I run the model.  I need to refresh the database (in ArcCatalog, right click db connection > refresh) before the feature class table will update.  Is there a tool that I can add to modelbuilder that will refresh the database before the Table Select tool runs so that it is running on updated data.  Ultimately this needs to run as a scheduled task so no manual process should be used.
ArcGIS 10.2.2
SQL Server db
Sharon
WesMiller
WesMiller
Not sure if this will work. Have a look at RefreshCatalog—Help | ArcGIS for Desktop
SharonZastre
Thanks Wes.  Adding that code to the exported python script works.
arcpy.refreshcatalog({file path to database connection file})
