Limiting outFields on Attribute Table Related Query
1634
05-26-2016 08:22 AM
SethLewis1
We're attempting to limit the number of fields that are returned by a relationship query and are being displayed in the Attribute Table.
I've looked in _RelationshipTable.js, specifically lines 197-201 and have modified these but the entire schema still is coming through.
var relatedQuery = new RelationshipQuery();
          relatedQuery.objectIds = selectedIds;
          relatedQuery.outFields = ofs.length ? ofs : ["FIELD1", "FIELD2"];
          relatedQuery.relationshipId = ship.id;
          relatedQuery.returnGeometry = false;
In addition, I receive an error in the console when I click on 'show related records' in a popup and fire the query (see attached).
I appreciate any help.
RobertScheitlin__GISP
Seth,
  I see that error all the time from the AT widget (some I would not be concerned with it).
The ofs.length is normally going to be defined so you will not make it to your ["FIELD1", "FIELD2"] portion of code.
I would look at something more like:
if(relatedTableInfo.name === "x"){
    relatedQuery.outFields = ["FIELD1", "FIELD2"];
}else{
   relatedQuery.outFields = ofs.length ? ofs : ["*"];
