feature dataset - transformation used
2733
05-21-2016 03:53 AM
danbecker
sde geodatabase / feature dataset A
WGS84 UTM Zone 11N - meters
file geodatabase / feature dataset B
NAD83 State Plane Arizona East - US Feet
Question:
When I export (feature class to feature class tool) from feat. dataset A to feat. dataset B, what geographic transformation is used to convert the datum from WGS84 to NAD83? Can this be specified, like you can when using the projection tool?
thanks.
JoshuaBixby
MVP Esteemed Contributor
Idea came from StackExchange:  What happens to feature class when importing to feature dataset?
From Esri documentation:  About importing feature classes​.
Suppose you want to import a feature class that's in another coordinate system. For example, you may want to import a feature class that uses the North American Datum (NAD) 1927 coordinate system into a feature dataset that uses the NAD 1983 coordinate system. To import the feature class, use the Project tool to simultaneously import the data and convert it into the new coordinate system.
Learn more about the Project tool reference
If the feature class you're importing is already in the coordinate system you want it to be in for the geodatabase, use the Feature Class To Feature Class or Feature Class To Geodatabase tools to import the data. The feature class you create with these tools can standalone or import into an existing feature dataset.
JoshuaBixby
