Check to see if Layer is visible at current map extent
4454
05-20-2016 03:20 PM
AdamCrateau1
Is there a way to verify if a layer in the map is visible at the current map extent?   FeatureLayer has a .maxScale property which can be used for this.  I don't see anything similar for the LayerInfo class.   Thanks for any suggestions.
RobertScheitlin__GISP
Adam,
LayerInfo has a maxScale and minScale. The WAB LayerInfos object you can get by using
LayerInfos.getInstance(this.map, this.map.itemInfo).then(lang.hitch(this, function(operLayerInfos) {
code as referenced in the LayerInfos class—Web AppBuilder for ArcGIS (Developer Edition) | ArcGIS for Developers
will allow you to get
array.forEach(operLayerInfos.getLayerInfoArray(), function(layerInfo) {
   var isVisible = layerInfo.layerObject.visibleAtMapScale;
Adam,
AdamCrateau1
The layerObject property appears to expose all the underlying FeatureLayer properties -- exactly what I needed, Thank you!
