Zoom to a feature on a mouse click event
9595
7
05-20-2016 01:31 PM
RoxanneWilson
So, working on my first app and I have a point layer with a few locations in it.  I'm trying to create an event where, when the user clicks on a location, the map extent zooms to that location.  This is what I have so far and it doesn't work (not a shocker)....
layerName.on("click", function (zoom) {
  map.zoom (zoom.layer.setZoom(4));
PanagiotisPapadopoulos
on this function
layerName.on("click", function (event) {
take the selected geometry event.graphic
and zoom on the map
map.centerAndZoom(event.graphic.geometry, 4);
RickeyFight
Are you using a sample?
Can you post more of your code?
TomSellsted
Roxanne,
Zoom is not a method of map.  When a graphic in a feature layer is clicked, it will return the graphic,  You can then use the graphic geometry or the event mapPoint to zoom to that location.  Here is a further explanation:
FeatureLayer | API Reference | ArcGIS API for JavaScript
It should look something like this:
    map.centerAndZoom(event.mapPoint, 4);
Regards,
Tom
RoxanneWilson
I've added that into my code, but nothing is happening yet.
Do I need to add something else?  I've been reading about event listeners, but I don't understand a lot of that quite yet.
FC_Basson
The click tolerance might cause that you are just missing the features with the click event and therefore nothing is happening.  Try setting the click event on the map object.
on this function
and zoom on the map
RoxanneWilson
This doesn't appear to do anything either.
layer.on("click", function (event) {
RoxanneWilson
Using developer tools, I found there was an error with another part of my code.
