adding layer on top of eSearch widget
4695
05-16-2016 08:48 PM
NaveenKumarKairamkonda
I added one layer on top of eSearch widget and its working in fine when we launch in WAB. I saved and  downloaded the code of updated eSearch widget. I found the same code as before adding layer to it and also I have seen in server/apps/2/widgets/eSearch/config.json, but 'config.json' file showing the same code with some other services layers. Where I can find the updated code after adding layers ?
Can anyone help???
Thanks in advance.
RobertScheitlin__GISP
NaveenKumar,
  In WAB once you configure a widget using the widgets settings page and then save, a new json file is added in a different location. Look in this path: [install dir]\server\apps\2\configs\eSearch\config_Enhanced Search.json
NaveenKumar,
Thanks Robert...
Naveen,
Glad to help. Make sure you mark this post as answered by clicking on the "Correct Answer" link on the reply that answered your question.
