how to change version for one map
2993
05-16-2016 08:22 AM
AlexanderGray
Honored Contributor
Is there a way I can use change version and apply to only one map?  When I do change version from the versioning ribbon tab, it applies to all layers in all maps, not just the currently visible map (except other map's datasource is not updated until you switch the list by in the TOC.)
Tags (1)
AdrianWelsh
MVP Honored Contributor
Alexander,
From looking at the tool,  Change Version—Data Management toolbox | ArcGIS for Desktop  , it looks like if all the layers are in the same workspace, then the version will change for all of them, like you are seeing. Maybe you could appropriate a certain layer in a different workspace, then change the version?
George_Thompson
Esri Notable Contributor
You could add a new database connection with that version set in the properties and then add the data layer that you want from that version.
--- George T.
