Can A Widget Send Message to LayerList Widget?
2672
05-12-2016 02:58 PM
LeiZhou1
When I use 2 different publishData functions inside startup () of Widget A, I want to send out the message: ‘ABCD’. See codes below:
startup: function() {
this.inherited(arguments);
        this.publishData({
               message: 'ABCD'
        this.publishData({
              message: 'XYZ'
} // start up ends here
Then I set up the onReceiveData function in Layer List widget as the following; I want to receive this signal 'ABCD' from Widget A and display it (I don’t want XYZ to be passed since it will be used for another function). See codes below:
onReceiveData: function (name, widgetId, data, historyData) {
if (name === 'Widget A'&& data.hasOwnProperty(‘ABCD')) {
alert("The Layer List Widget received the signal ABCD");
    this._clearLayers();
    this.showLayers();
        } //if ends here
But I never see any alert pop up window coming out. Why cann’t my onReceiveData function in LayerList Widget receive this message ‘ABCD’ from Widget A? Many thanks!
RobertScheitlin__GISP
Lei,
  If the data has already been published before the layerlist widget is open and listening then you need to add: this.fetchData(); to the startup function in the layerlist widget.
Lei,
LeiZhou1
Thanks!
