Unable to find differences between two versions using ArcObjects SDK for JAVA
3940
05-12-2016 04:46 AM
Vara_PrasadM_S
Hi All,
I am trying to fetch the differences between a child version and its parent version which is the Default Version through ArcObjects SDK for JAVA. I am not getting any results into objectIDs and differenceRows when I called "differences" function as below...
differenceCursor = versionedTable.differences(commonAncestorTable, esriDifferenceType.esriDifferenceTypeInsert, null);
differenceCursor.next(objectIDs, differenceRows);
Followed the sample code given in below help document. We are using V 10.2.1
ArcObjects 10 .NET SDK Help
However, when I used "Versioning" tool bar and used "Version Changes" tool, I am able to see the changes. Could some one please help me with this.
Thanks & Regards,
Vara Prasad.
Tags (1)
Vara_PrasadM_S
I could able to solve this. By assigning empty arrays to out parameters of "next" method instead of null object.
Thanks & Regards,
Vara Prasad.
Vara_PrasadM_S
Here is my code in JAVA. I tried same approach in .NET and it worked perfect. However, in JAVA ArcObjects, I am not getting any results, always giving 'null' for both "objectID" and "differenceRow". Could someone please help me.
IVersionedWorkspace versionedWorkspace = new VersionedWorkspace(workspace);
              IVersion childVersion = versionedWorkspace.findVersion("SDE.Test");
              IVersion parentVersion = versionedWorkspace.getDefaultVersion();
              // Cast to the IVersion2 interface to find the common ancestor.
              IVersion2 childVersion2 = new IVersion2Proxy(childVersion);
              commonAncestorVersion = childVersion2.getCommonAncestor(parentVersion);
                  // Cast the child version to IFeatureWorkspace and open the table.
              IFeatureWorkspace childFWS = new IFeatureWorkspaceProxy(childVersion);
              ITable childTable = childFWS.openTable(tableName);
              // Cast the common ancestor version to IFeatureWorkspace and open the table.
              commonAncestorFWS =  new IFeatureWorkspaceProxy(commonAncestorVersion);
              commonAncestorTable = commonAncestorFWS.openTable(tableName);
              // Cast to the IVersionedTable interface to create a difference cursor.
              IVersionedTable versionedTable =  new IVersionedTableProxy(childTable);
              int countChildRecords = childTable.rowCount(null);
              int countParentRecords = commonAncestorTable.rowCount(null);
              // Create output variables for the IDifferenceCursor.Next method and a FID set.
              IFIDSet fidSet = new FIDSet();
              IRow[] differenceRow = null;
              int[] objectID = null;
              // Step through the cursor, showing the ID of each modified row.
              differenceCursor.next(objectID, differenceRow);
Thanks & Regards,
Vara Prasad.
Vara_PrasadM_S
Thanks & Regards,
Vara Prasad.
