com.esri.ges.messaging.MessagingException: GeoEvent producer is null
2591
05-10-2016 04:12 PM
MunhwanGim
hi, all,
is there anyone to give me a guide what possibly for me to check to resolve the error the custom Adapter code returns with the following message?
In my adapter implemenation,
  public void receive(ByteBuffer buffer, String channelId)
       new Thread(new GeoEventProducer(channelId, getMessage(buffer))).start();
The class of GeoEventProducer is
  private class GeoEventProducer implements Runnable
    private String channelId;
    private byte[] message;
    public GeoEventProducer(String channelId, byte[] message)
      this.channelId = channelId;
      this.message = message;
    @Override
    public void run()
  String data;
  data = new String(message);
  data = "<root>" + data + "</root>";
  GeoEvent[] geoEvents = translate(data);
  if (geoEvents != null){
  for (int i=0; i < geoEvents.length; i++){
            geoEventListener.receive(geoEvents);
  } else {
  LOGGER.error("UNS Adapter. No GeoEvent translated.");
2016-05-10 12:18:47,717 | ERROR |  #13 - Multicast | GeoEventServiceRouteBuilder      | ceRouteBuilder$StreamRefProducer  239 | 245 - com.esri.ges.framework.processing.camel-processing - 10.3.0 | Service '0e121747-1410-4edc-82bf-555d6d97e2e9' failed to send GeoEvent to destination 'c256a35d-2a2c-4127-8c5f-1526b66c8292':
com.esri.ges.messaging.MessagingException: GeoEvent producer is null.
  at com.esri.ges.processing.camel.GeoEventServiceRouteBuilder$StreamRefProducer.send(GeoEventServiceRouteBuilder.java:232)
  at sun.reflect.GeneratedMethodAccessor138.invoke(Unknown Source)
  at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)[:1.7.0_65]
  at java.lang.reflect.Method.invoke(Method.java:606)[:1.7.0_65]
  at org.apache.camel.component.bean.MethodInfo.invoke(MethodInfo.java:407)[165:org.apache.camel.camel-core:2.12.3]
  at org.apache.camel.component.bean.MethodInfo$1.doProceed(MethodInfo.java:278)[165:org.apache.camel.camel-core:2.12.3]
  at org.apache.camel.component.bean.MethodInfo$1.proceed(MethodInfo.java:251)[165:org.apache.camel.camel-core:2.12.3]
  at org.apache.camel.component.bean.BeanProcessor.process(BeanProcessor.java:166)[165:org.apache.camel.camel-core:2.12.3]
  at org.apache.camel.management.InstrumentationProcessor.process(InstrumentationProcessor.java:72)[165:org.apache.camel.camel-core:2.12.3]
  at org.apache.camel.processor.RedeliveryErrorHandler.process(RedeliveryErrorHandler.java:398)[165:org.apache.camel.camel-core:2.12.3]
  at org.apache.camel.processor.CamelInternalProcessor.process(CamelInternalProcessor.java:191)[165:org.apache.camel.camel-core:2.12.3]
  at org.apache.camel.component.direct.DirectProducer.process(DirectProducer.java:51)[165:org.apache.camel.camel-core:2.12.3]
  at org.apache.camel.processor.SendProcessor.process(SendProcessor.java:110)[165:org.apache.camel.camel-core:2.12.3]
  at org.apache.camel.util.AsyncProcessorHelper.process(AsyncProcessorHelper.java:105)[165:org.apache.camel.camel-core:2.12.3]
  at org.apache.camel.processor.MulticastProcessor.doProcessParallel(MulticastProcessor.java:712)[165:org.apache.camel.camel-core:2.12.3]
  at org.apache.camel.processor.MulticastProcessor.access$200(MulticastProcessor.java:83)[165:org.apache.camel.camel-core:2.12.3]
  at org.apache.camel.processor.MulticastProcessor$1.call(MulticastProcessor.java:293)[165:org.apache.camel.camel-core:2.12.3]
  at org.apache.camel.processor.MulticastProcessor$1.call(MulticastProcessor.java:278)[165:org.apache.camel.camel-core:2.12.3]
  at java.util.concurrent.FutureTask.run(FutureTask.java:262)[:1.7.0_65]
  at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)[:1.7.0_65]
  at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)[:1.7.0_65]
  at java.lang.Thread.run(Thread.java:745)[:1.7.0_65]
