AGOL Share Multiple Items
5621
7
05-06-2016 02:43 AM
markrobey1
I want to share multiple items in an AGOL folder. I can select all the items, but the only options to appear are: Delete, Move, Change Owner...no Share option. I am the owner and have admin privileges. The items include web apps, web maps, and tile layers.
markrobey1
The problem is caused by Ad Block Plus. Disable it for AGOL and the problem is resolved.
KellyGerrow
Esri Alum
Hi Mark,
What browser are you using? Can you share a screenshot of what you are seeing?
-Kelly
markrobey1
Hi Kelly,
Chrome Version 50.0.2661.102 m
KellyGerrow
Esri Alum
Hi Mark,
I can't reproduce this issue with the same browser in chrome. In your organization settings, are you able share content outside of your organization? Is the issue still occurring?
-Kelly
markrobey1
Hi Kelly,
Yes, that option is selectable and is currently selected. The issue issue is ongoing.
Mark
markrobey1
AdrianWelsh
MVP Honored Contributor
Wow, interesting. I suppose if you went to another browser things worked so the main difference was the Ad Block Plus? I wonder why this is causing a problem since there aren't any ads in AGOL (maybe the ad blocker is picking up on something that it shouldn't be?).
markrobey1
Tried it in Firefox with Ad Block Plus and is ok.
