geotagger field not showing in output
4375
04-30-2016 08:55 AM
BobbySells
I have a geotagger running on geofences but my email output isn't displaying the geofence field.  how can I see the output of the geotagger?
MarkBramer
Hi Bobby,
Whenever I need to see what is emitted from any component in a GeoEvent Service, I wire up a JSON file output directly after the component I'm curious about.  The great thing about the JSON file output is that the field names are written as well as the values (csv files do not have the field names).  So create a new JSON file output, and modify your GE Service to wire up your geotagger to output to the JSON file output, then look in the JSON file to see your data with the field names and values.
Mark
by Anonymous User
Not applicable
Did you have any success resolving this? I'm running into the same issue. I confirmed via JSON output that the field name is correct. In the attached EmailOutputConfig.png is my email config. the description field will write to the email but the HazardArea field will not. I have also included a screenshot of the JSON.
