Story Map - font size in map notes
2711
04-25-2016 01:40 PM
AnneMills1
I have several maps in the Story Map application (ArcGIS Online) and have used Map Notes to add detail and photos about features on the maps. However, when I copy and paste the text from a word file, the font size is very inconsistent in the map notes. Is there a way of maintaining a consistent font size throughout the map note? i.e. bullet text is smaller than paragraphs etc. Can I add a font size tag to the source code in the map note or is there a means of maintaining font size throughout.
Anne
Tags (1)
DanPatterson_Retired
you probably can, but copy and paste from word may be bring over attributes, have you tried a text editor like Notepad or Notepad++ to see if you can just get pure text and let the application handle the attributes
AnneMills1
Thanks, I will give that a try. I thought about doing that but was hoping for a really easy fix. This should work.
Best Regards,
Anne
