Implementing Multiple Regression Equation
3315
04-26-2016 10:23 AM
DavidGordon1
I'm having trouble understanding how to implement a multiple regression equation in ArcGIS 10.3.  I've already performed the regression in SAS and have the necessary coefficients, and so I don't need to redo an analysis with one of the Modeling Spatial Relationship tools in ArcGIS.  I simply need to create a new raster that is derived from my existing equation based on values from 3 different input rasters.  I've examined the Combine Tool, but that converts my numeric values to integers.  Weighted overlay apparently is based on ranking data.  What am I missing?
Dave
DanPatterson_Retired
there is the raster calculator... listed in the toolset as well... I will save you the search
Raster Calculator—Help | ArcGIS for Desktop
The complete tool listing is here An overview of the Spatial Analyst Toolbox—Help | ArcGIS for Desktop
you can create rasters of constant values, either integer or float, and your basic math functions are built in (is Plus, Times)
If your rasters are used as variables, just ensure that their extents, cell size and snap raster are established in the
Environments tab of any tool you use, don't assume that global settings are carried forward
DavidGordon1
If I understand you correctly, I need to generate a new raster for every math operation in the in the regression equation?  That's straightforward, but it seems inefficient. Thanks Dan.
DavidGordon1
That will do it!  Thank you Dan!
