SQL syntax for numeric wildcard in file geodatabase
7571
10
04-21-2016 11:07 AM
FrankPrice
Does anyone know what the appropriate SQL syntax is for selecting any record that contains any number within a text string in a field using Select by Attributes with a file geodatabase feature class.  The help page mentions using the pound sign as a numeric wildcard but this isn't working for me so maybe it only works for personal geodatabases?  And I know I can use the field calculator and python or VB to do this in various ways but it just seems like there should be a quicker way to do it with SQL using Select by Attributes.  I'm thinking there should be something like Field_name LIKE '%#%' where the pound sign is any number.
Thanks for any pointers!
WesMiller
Obs_data_temp LIKE '%0%' OR
Obs_data_temp LIKE '%1%' OR
Obs_data_temp LIKE '%2%' OR
Obs_data_temp LIKE '%3%' OR
Obs_data_temp LIKE '%4%' OR
Obs_data_temp LIKE '%5%' OR
Obs_data_temp LIKE '%6%' OR
Obs_data_temp LIKE '%7%' OR
Obs_data_temp LIKE '%8%' OR
Obs_data_temp LIKE '%9%'
WesMiller
If your data is stored in an sql database try this PATINDEX('%[0-9]%', yourfieldhere ) > 0
FrankPrice
Thanks, but I just get "An invalid SQL statement was used".  Is the PATINDEX function specific to SQL Server?  I need something that will work on a file geodatabase...
WesMiller
Try this for a File geodatabase
yourfieldhere LIKE '%[0-9]%'
FrankPrice
I tried that previously and again when you suggested.  It doesn't throw an error but doesn't select anything either (yes, there are definitely numbers in the field I'm querying).
WesMiller
Are you in a file geodatabase?
Could you post a sample 5-10 records?
FrankPrice
Check out the attached.  I deleted most of the fields but tested and still have the same problem.  Try the Obs_data_temp field.
WesMiller
FrankPrice
Well, not very concise but I guess it does the job...
WesMiller
I've looked a few times for a good answer to this question, unfortunately unless your in server or a personal geodatabase there doesn't seem to be a good answer.
