Question of Creating a Simple Widget
3149
04-19-2016 01:24 PM
JakeCliffton
I am creating a simple widget with the same function as the following link:
http://developers.arcgis.com/javascript/sandbox/sandbox.html?sample=query_nomap
I just want to open this widget, click one button to do the query,  and display the query results inside the widget pane (I will use a different url later). Here are my codes for widget.js and widget.html. I am confused why my codes are not working. My question is how to make the results display in the widget.html or widget pane? Why the JS API codes are not working in the return declare () method?  Any hints are very helpful. BTW, I don't have setting files or manifest json files. Thanks!
widget.js as the following:
define(['dojo/_base/declare', 'dojo/_base/array', 'jimu/BaseWidget','dojo/dom', 'dojo/on',
        'esri/tasks/query', 'esri/tasks/QueryTask', 'dojo/domReady!'],
function(declare, array, BaseWidget,dom, on, Query, QueryTask) {
  return declare([BaseWidget], {
    baseClass: 'jimu-widget-widgetb',
       var queryTask = new       QueryTask("https://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Demographics/ESRI_Census_USA/MapServer/5");
        var query = new Query();
        query.returnGeometry = false;
        query.outFields = [
          "SQMI", "STATE_NAME", "STATE_FIPS", "SUB_REGION", "STATE_ABBR",
          "POP2000", "POP2007", "POP00_SQMI", "POP07_SQMI", "HOUSEHOLDS",
          "MALES", "FEMALES", "WHITE", "BLACK", "AMERI_ES", "ASIAN", "OTHER",
          "HISPANIC", "AGE_UNDER5", "AGE_5_17", "AGE_18_21", "AGE_22_29",
          "AGE_30_39", "AGE_40_49", "AGE_50_64", "AGE_65_UP"
        on(dom.byId("execute"), "click", execute);
        function execute () {
          query.text = dom.byId("stateName").value;
          queryTask.execute(query, showResults);
        function showResults (results) {
          var resultItems = [];
          var resultCount = results.features.length;
          for (var i = 0; i < resultCount; i++) {
            var featureAttributes = results.features.attributes;
            for (var attr in featureAttributes) {
              resultItems.push("<b>" + attr + ":</b>  " + featureAttributes[attr] + "<br>");
            resultItems.push("<br>");
          dom.byId("info").innerHTML = resultItems.join("");
widget.html
<div>
<input type="text" id="stateName" value="California">
    <input id="execute" type="button" value="Get Details">
    <br />
    <div id="info" style="padding:5px; margin:5px; background-color:#eee;">
    </div>
</div>
RobertScheitlin__GISP
Jake,
  Your main issue is that your code was not in a main widgets function like postcreate or startup. I also updated your code to use the stand methods for access template elements and global vars.
Jake,
JakeCliffton
Thank you so much!
