Hi, do not know how to ask this question because I am not sure where the problem lays.
I am converting my applications to 10.4. They are currently on 10.3 using VB2012. I can upgrade to 10.4 in VB2012 after I set the .NET Framework to 4.5. So that looks good.
Now the issue, I am trying to upgrade to 10.4 using VB2013 and I get the following errors. On what information I can find I am still not clear on the problem. I am pretty sure it is a VB2013 issue, but I just want to figure out is it a 10.4 or VB2013 issue. And then what does it mean?
Error 1. Class 'AddInStartUpProject' must either be declared 'MustInHerit' or override the following inherited ' MustOverride' member(s): ESRI.ArcGIS.Desktop.AddIns.AddInEntryPoint : Protected Friend MustOverride Function Initialiaze(hook As Object) As Boolean.
Error 2. 'Protected Function Initialize (hook as Object) as Boolean'
cannot shadow a method declared 'MustOverride'.
Thank you for your time. Dale,
