Can you make on screen widgets open like header controller widgets?
3082
04-18-2016 02:24 PM
ThomasSpindler1
This in reference to the Tab Theme.
Basically, I want the on screen widgets to open where header controller widgets do.  If Layer List is open and you use an on screen widget (like Draw), there is little to no room left to view the map.
Tags (1)
RobertScheitlin__GISP
Thomas,
  No that is not possible without a serious re-write of the widget.
Thomas,
  So what you need to do is not use the onScreen widget placeholders then. Just add all your widgets to the Sidebar controller widget.
ThomasSpindler1
Thanks, but I would like to avoid using the using the drop down to select more widgets.  Ideally I’d like to have every icon visible.  Is this possible?  I appreciate your help!
Thomas,
