Setting initial position on a widget
3463
5
04-15-2016 06:45 AM
deleted-user-0W0-oLHxDjCX
I’m trying to change default position of the Layerlist widget, but until now I didn’t have much progress.
    - I tried set left value position into config.json;
    {             "uri":"widgets/LayerList/Widget",             "version":"1.4",             "id":"widgets_LayerList_Widget_17",             "name":"LayerList",             "label":"Lista de Camadas",             "index":3,             "config":"configs/LayerList/config_Lista de Camadas.json",             "openAtStart": true,             "position":{                "left":68               }          }
  • I Tried to modify in PanelManager and WidgetManager:
    if(pid === 'widgets_LayerList_Widget_17_panel'){                   options.position.left=68;                   console.log(options);                   console.log(this.widgetManager);                 }
    I just had a little progress setting in css “left:68!important”, but with this I lose a mobily of the widget as was to be expected, but I didn’t want this. 😞
RobertScheitlin__GISP
Ezequias,
  What theme are you using?
LaunchpadTheme.
Sure I have answered this before, here:
Layer List auto start location change
Thanks a lot Robert Scheitlin, GISP it works perfectly.
Best regards
Zeke
Zeke,
Don't forget to mark this as answered by clicking on the "correct answer" link on the reply that answered your question.
