About remove a field from Attribute Table Widget
1580
04-13-2016 10:26 AM
LeiZhou1
I need to remove a field from the Attribute Table, I have unchecked the field from Web Map, query widget, and attribute table widget itself, but the attribute table still read info from map service. Also I changed the field alias from these places, it does not display correct text and format I changed. Is this a bug in ESRI's Attribute table? Do we have any solution on it? Thanks!
