Feature Layer multiple definition expressions
4482
04-10-2016 12:47 PM
EricBianchi1
For example, if I have the code:
featureLayer.setDefinitionExpression("TYPE='BLUE'");
Can I set multiple expressions such as TYPE='RED' and TYPE='BLUE'?
If so, what is the proper syntax to do so?
Thanks!
RobertScheitlin__GISP
Eric,
  Sure it would be:
featureLayer.setDefinitionExpression("TYPE='BLUE' OR TYPE='RED'");
Eric,
  Sure it would be:
Eric,
   AND  is used when you want another field to have another value like "Type = 'RED' AND Lot = 'STUDENT'"
KenBuja
MVP Esteemed Contributor
If you have many types, you can also use the syntax
featureLayer.setDefinitionExpression("TYPE in ('BLUE', 'RED')");
