Move features forward/backward in Layout
8620
04-05-2016 11:46 AM
by Anonymous User
Not applicable
Something so simple.  Does anyone know how to move a feature in layout mode forwards/backwards?
We make white polygon boxes to hold information like scalebars and north arrows and in ArcMap it's a right click - bring feature forward...I can't seem to find the equivalent in pro.
MervynLotter
MVP Regular Contributor
Hi Kelly
If I understand your question correctly, then the solution is found under
the Contents pane where you simply need to change the order in which the
features are drawn (i.e. the scale bar should be above a white box). Just
click and drag the item/element to change the order.
Regards
MervynLotter
Hi Kelly
Regards
AdrianWelsh
MVP Honored Contributor
I love how intuitive this is. Similar to MS PowerPoint Selection Pane. However, it took me a long time to figure this out! I guess Pro is moving away from the ArcMap model of "10 ways to do everything". Here's to more learning new ways...
DanPatterson_Retired
JeremyWright
Their z-order in the TOC controls their drawing order.  Just drag the white polygon boxes below the north arrow/scalebar.
