I'm migrating from ArcGIS Runtime for WPF and have some problems with handling local data services.
I have several local datasources (mpk and tpk) and try to load these into a MapView. When particular layers are initialized there should happen some other stuff in my app.
Strange thing is, when I load a dynamic service BEFORE I start a ArcGISLocaltiledLayer the PropertyChanged event of the tiled layer never get's fired. When I reverse the order of loading the service and the tiled layer (first tiled layer afterwards LocalMapService) everything works fine.
Is there any workaround for this behaviour, other than changing the load order (what will be a total mess to my app logic on this and related points)?
Edit: Attached a VS2013 solution to repro.
