How to Open A file
3111
04-04-2016 06:14 PM
AlanEnglish
Your status update has been posted in Web AppBuilder Custom Widgets
Is there a widget or is it even possible to grab a table value that is not an URL but a path to a file on a local server that the system OS can act on with open file?
i.e. "\\gisdb\gis_production\managed_data\Public_safety\PrePlans\8401 W Monroe St- Council Chambers.pdf"
JakeSkinner
Esri Esteemed Contributor
Hi Alan,
Out-of-the-box this is not possible due to security.  See the following KB Article for more information and a possible workaround:
45140 - Is it possible to create hyperlinks for data stored in a local drive in an ArcGIS Online web...
RobertScheitlin__GISP
What you need to do is create a virtual directory in IIS that points to your UNC path and then store that url in a field to use in your web map.
