Using IfeatureCursor to location a feature
2947
04-04-2016 04:42 AM
IbrahimHussein
I have a IfeatureCursor that I initialized to null. When I try to set it with a IfeatsureSelection.SelectionSet.Search(,,out IfetureCursor) I get an error saying
cannot convert 'out ESRI.ArcGIS.Geodatabase.IFeatureCursor' to 'out ESRI.ArcGIS.Geodatabase.ICursor'
Code
            void SelectionChangedFunc()
                IFeatureSelection featSel = default(IFeatureSelection); //link to a feature selection
                IFeatureCursor selCur = null;                           //feature cursor to iterate
                IFeature f = default(IFeature);                         //link to a feature
                featSel = p_addressLayer as IFeatureSelection;
                MessageBox.Show("changed"); //debugging purposes
                if (featSel.SelectionSet.Count > 0)
                    featSel.SelectionSet.Search(null, false, out selCur);
                    f = selCur.NextRow();
                    MessageBox.Show(f.Fields.FindField("STR_NAME").ToString()); //debugging purposes
                    MessageBox.Show(selCur.Fields.FindField("STR_NAME").ToString()); //debugging purposes
Line 15 is where the issue is. I tried casting with no luck. Anyone come accross this issue or was able to successfully use a IfeatureCursor in C# SDK 10.4
DuncanHornby
MVP Notable Contributor
I've just tried using a IFeatureCursor in a search on a selection set using VBA in 10.4 and it worked for...
If your code is not actually accessing the geometry field, which it appears to be the case, why not try ICursor instead?
IbrahimHussein
Hi duncan, I actually figured it out. I had to use ICursor like you suggested, and then cast it as a IFeatureCursor after I call the SelectionSet.Search function.
SuryaNarayana
I am new to this ArcObjects coding. Could someone help me, how to convert ICursor to IFeatureCursor
