Add Field not working for multiple fields
6217
03-31-2016 09:09 AM
ThejaPutta
I wrote a few lines of Python code to add a set of fields if they are not already present in a feature layer. Here is my code.
# Import modules
import arcpy
input_table = "myFeatureLayer"
# Input fields to create if they are not present in the feature layer
input_fields = ["a", "b", "c", "d", "e", "f", "g"]
# Field type
attr_type = "SHORT"
for field in input_fields:
     if len(arcpy.ListFields(input_table, wild_card=field)) == 0:
          arcpy.AddField_management(input_table, field_name = field, field_type = attr_type)
Sometimes it runs through the first 3 fields on the list before raising an error and sometimes it only goes through 1 or 2 fields. There are couple of times when the whole code ran without issue and created the entire list of fields.
This is the error I get:
Runtime error  Traceback (most recent call last):   File "<string>", line 13, in <module>   File "c:\program files (x86)\arcgis\desktop10.3\arcpy\arcpy\management.py", line 3246, in AddField     raise e ExecuteError: ERROR 999999: Error executing function. Failed to execute (AddField).
Any suggestions or thoughts on what the issue might be?
Theja
DanPatterson_Retired
you need to set your work environment for one thing, the layer name isn't sufficient, check the example
Add Field—Help | ArcGIS for Desktop
ThejaPutta
Thanks Dan!
That worked! I was using this in a tool earlier and the environment workspace that was set for the tool was different from the shapefile location.
I am still not very clear on why it works for the first one or two fields before raising an error.
I think what you probably want to do is make sure that the field doesn't already exist.  However, when you use ListFields, it returns a field object, from which you have to get its name and check to make sure it isn't in there.
I then would check the fields that you want to add ( ie your_fields in my example below) and see if they are 'in' the list of fields (via their name) that already are in there.
from here... ListFields—Help | ArcGIS for Desktop
featureclass = "c:/data/municipal.gdb/hospitals"
field_names = [f.name for f in arcpy.ListFields(featureclass)]
for fld in your_fields:
    if fld in field_names:
        print("this field {} exists already".format(fld))
    else:
        then proceed with adding the field as you have done
