generate kmz in code in Arcgis Runtime .net?
3640
03-30-2016 05:26 PM
santiagomonedero
Hi, I am using kmz layers for image animation pourposes over a sceneview in Arcgis Runtime.This works fine but involves a lot of steps in code ( generate and export a png file, create kml, zip kml to kmz,  import kmz to an Arcgis kml layer) .
I was wondering if there is a directe way to create the same effect wihout having to use an external file.
thanks
dotMorten_esri
Esri Notable Contributor
At this point the runtime does not support authoring kml/kmz. It is however on our future roadmap.
PhilipO_Gorman
+1 - In my case I want to update the position of an image on the map at 10Hz.
Here is the code https://bitbucket.org/snippets/philipogorman/LE8kr
As you can see it is not very efficient for what I want to do.
Philip
