Custom widget eSearch Not able to load map services
2386
5
03-17-2016 07:26 AM
RonHire
Hi
When I try to load a map service in the eSearch widget I get a popup up "Search Layer Map Service Failure". This only occurs when the map service I am trying to load has Relationships. I have some map services with 1 relate and some with 2. I can load map services that do not have Relationships. Any suggestions would be appreciated.
RobertScheitlin__GISP
Ron,
  Can you check what version you are running by holding the Alt key and clicking anywhere on the widget? A dialog will display giving you the widgets version info. I remember this being an issue at one time that had been fixed.
RonHire
Hi Robert
I was unable to get the version using the alt key. The manifest.json file shows version 1.2.0.6
Thx.
Ron Hire
Information Technology Analyst / Programmer II
City of Phoenix
200 W. Washington St.
Phoenix Arizona 85003
Ph. 602.262.7893
Ron,
Yes this issue was definitely fix since 1.2.0.6. There are dozens of reasons to upgrade to WAB 1.3 and the eSearch 1.3.0.2
RonHire
Hi Robert…again
I just downloaded version 1.3.0.2 and the preliminary results are my map services with relates will now load.
Just wanted you to know, so you did not spend a lot of time on this. I will let you know if I have any issues
Thanks for your quick reply……
Thx.
Ron Hire
City of Phoenix
Ph. 602.262.7893
Ron,
  Don't forget to mark this thread as answered.
