Using arcpy.da.Walk to mosaic multiple rasters?
3276
03-16-2016 04:52 AM
DonRaymond
I have many hundreds of GeoTiff files to mosaic. The problem is that they are stored in a sub-directory structure whereby I need to traverse down into each sub-directory, mosaic all rasters in that location, and then go back up and down into all the other sub-directories sequentially to perform the same action. Some example directories would appear as follows:
c:\dem\250k\001  (do all rasters here)
.............       \002 (do all rasters here)
.............       \003 (do all rasters here)
I found the following Python snippet on the forum, but it finds and mosaics all rasters in all sub-directories to a single output layer. I need to find a way to "walk" into the sub-directories and output a single output for each. Thanks.
import arcpy
import os
workspace = r"c:\dem\250k"
rasters = []
walk = arcpy.da.Walk(workspace, topdown=True, datatype="RasterDataset")
for dirpath, dirnames, filenames in walk:
    dirpaths.append(os.path.join(dirpath, dirnames)
    for filename in filenames:
        rasters.append(os.path.join(dirpath, filename))
ras_list = ";".join(rasters)
arcpy.MosaicToNewRaster_management(ras_list,workspace,
                                  "test.tif", "", "16_BIT_SIGNED", "", "1", "LAST")
# return SA license
arcpy.CheckInExtension("Spatial")
JakeSkinner
Esri Esteemed Contributor
Hi Don,
Here is a an example on how to do this.  The below example mosaicks 3 band rasters together in each directory.  It outputs a new TIF called 'Mosaic.tif' to each directory.
import arcpy, os
from arcpy import env
env.workspace = r"E:\Temp\Python\UserData"
walk = arcpy.da.Walk(env.workspace, topdown=True, datatype="RasterDataset")
    print dirpath
    rasterList = []
    for file in filenames:
        raster = os.path.join(dirpath, file)
        rasterList.append(raster)
    try:
        arcpy.MosaicToNewRaster_management(rasterList, dirpath, "Mosaic.tif", "", "", "", 3)
    except:
        pass
JakeSkinner
Hi Don,
import arcpy, os
    print dirpath
    rasterList = []
    try:
    except:
        pass
DonRaymond
Thanks very much for your help, Jake. I will give this a try today.
