Geometric Network, issue while moving features
3540
5
03-09-2016 12:50 AM
MuhammadAttique
Hi , I am working with Geometric Network , in some cases I have to move a group of features to another X,Y position, but when I am trying to move those group of features to new XY location , it can't be move , only by dragging the group is possible. but it took too much time because in some cases distance is very far from the location..
any idea how to solve it .
thanks in advance.
Muhammad Attique
NeilAyres
Software version?
How far is "very far"?
Have you checking your snapping distance?
MuhammadAttique
Hi Neil Ayres,
I am using ArcGIS desktop 10.2.1 and
distance around  more then 10000 meters , snapping is not an issue ,
Just want to move group of features.
JoeBorgione
Just an FYI: Geometric networks are a different breed than the networks used in Network Analysis.  That said, what are the features you are trying to move?  I could see moving a number of points to the the same XY location, but lines not so much.
MuhammadAttique
Hi Joe ,
I have group of features, a polygon and inside polygon there are points , lines.
these feature represent a network.
Is it possible to move all features at once to any new XY location ?
NeilAyres
Well within an edit session, the only way would be to select then drag each feature to a new location.
But why are you moving these features 10,000 metres?
Is this not some sort of coordinate problem if they are so far away from where they are supposed to be?
Could try rubber sheeting the features. But that is mainly designed for more near scale shifts.
