Asking
2511
03-08-2016 01:45 AM
ThanhtikeooDOM
I would like to combine the data in two shape file. I cannot combine and I don't know what happen. Please explain me how can I do.
Thanks to all.
Than Htike Oo
RobertMueller_Jr1
Than-
I might reference you to Larry Zhang's comment on this question (How can I merge features in ArcGIS Online? ). I haven't found a way yet to do this programmatically. I would probably suggest the Analysis Widget. If you want to do this programmatically through (via the Spatial Analysis Service, i.e. still uses credits) check out this from ESRI Development support;
developer-support/web-js/merge-layers-tool at master · Esri/developer-support · GitHub
-Bob
var mergeLayersTool = new MergeLayers({
  inputLayer: inputLayer,
  mergeLayers: [mergeLayer],
  map: map,
  outputLayerName: "MyTestLayer",
  portalUrl: "http://www.arcgis.com",
  showHelp: true,
  showSelectFolder: true
}, "merge");
mergeLayersTool.startup();
mergeLayersTool.on("job-result", function(result) {
   map.removeLayer(inputLayer);
   map.removeLayer(mergeLayer);
   map.addLayer(new FeatureLayer(result.value.url));
