Python arcpy.da.InsertCursor how to create a newRow()
16541
7
03-04-2016 07:40 AM
JoseSanchez
Hello everyone
I am converting a arcpy.InsertCursor  in arcpy.da.InsertCursor
How does this line works in arcpy.da.InsertCursor
  row = rows.newRow()
# Create insert cursor for table
rows = arcpy.InsertCursor("c:/base/data.gdb/roads_lut")
# Create 25 new rows. Set the initial row ID and distance values
for x in range(1, 26):
    row = rows.newRow()
    row.setValue("rowid", x)
    row.setValue("distance", 100)
    rows.insertRow(row)
DanPatterson_Retired
It doesn't exist any more
InsertCursor—Help | ArcGIS for Desktop
JoseSanchez
So how do I declare the row object now?
JamesCrandall
arcpy.InsertCursor
    row = rows.newRow()
    rows.insertRow(row)
fields = ['rowid', 'distance']
cursor = arcpy.da.InsertCursor('c:/base/data.gdb/roads_lut', fields)
for x in range(0, 25):
     cursor.insertRow((x, 100))
Not tested, just going off of the help doc
Edit: that link doesn't work if clicked, strange.  Just copy/paste url into a new browser address box.
Luke_Pinner
MVP Regular Contributor
You don't, you pass the values as a list/tuple directly to the insertRow method - it's in the help...
Methods
insertRow (row)
ParameterExplanationData Type
row
[row,...]
A list or tuple of values. The order of values must be in the same order as specified when creating the cursor.
When updating fields, if the incoming values match the type of field, the values will be cast as necessary. For example, a value of 1.0 to a string field will be added as "1.0", and a value of "25" added to a float field will be added as 25.0.
tuple
JamesCrandall
Broken link I think, Dan.
It has been happening a lot today... Xander and I found one this morning as well, links to the help files are flakey at best Timothy Hales​ is this due to the impending upgrades?  Spotty at best, but links sometimes work and sometimes don't if copied from a help topic.
TimothyHales
Esri Notable Contributor
I am not aware of any issues; however, there are a several issues being fixed with tonight's update. If it continues after the weekend, I will investigate it further.
