Python arcpy.da.SearchCursor error 'tuple' object has no attribute 'getValue'
8315
8
03-04-2016 05:47 AM
JoseSanchez
Hello everyone,
I am changing in my program the arcpy.SearchCursor  to arcpy.da.SearchCursor and when I run the code I am getting the following error message:
Python Error occurred
  # Get field objects from source FC AGREEMENT
  dsc = arcpy.Describe(AGREEMENT)
  fields = dsc.fields
  # List all field names except the OID field
  fieldnamesYesterday = [field.name for field in fields if field.name != dsc.OIDFieldName]
  curYesterday = arcpy.da.SearchCursor(AGREEMENT, fieldnamesYesterday)
  for  rowYesterday in curYesterday:
        agreementID = rowYesterday.getValue("AGMID")
        datetimeVal = rowYesterday.getValue("DIGIDATE")
        print agreementID
        print datetimeVal
DanPatterson_Retired
indentation errors if that is what you have
Accessing data using cursors—Help | ArcGIS for Desktop
RuthBowers
This is a matter of simply reading the help files. The two different cursors use different syntax.
First read this:
ArcGIS Help (10.2, 10.2.1, and 10.2.2)
Then read this:
This will answer your question.
JoseSanchez
Hello everyone,
I am following this sample to list all the fields:
Using arcpy.da.InsertCursor to insert an entire row that is fetched from a search cursor? - Geograph...
What is wrong with my code, could you please be more specific.
JakeSkinner
Esri Esteemed Contributor
Hi Jose,
You need to reference the fields using their list index.  For example, if AGMID is the 1st field, and DIGIDATE is the 3rd field, your code would be:
    agreementID = rowYesterday[0]
    datetimeVal = rowYesterday[2]
    print agreementID
    print datetimeVal
JoshuaBixby
MVP Esteemed Contributor
Are you following the code in the SE thread because that is what you are doing, i.e., inserting records from one dataset into another, or are you using the code just for its general structure?  If the former, it might be quicker to use either the Copy Features tool or Append tool.
JoseSanchez
The samples from ESRI always show a hardcoded list of fields ['fieldA', 'fieldB']  but in my case I need to read all the fields from the feature class, and list them in the "field_names" parameter.
arcpy.da.SearchCursor(in_table, field_names, {where_clause}, {spatial_reference}, {explode_to_points}, {sql_clause})
WesMiller
AndrewKeith3
Here is the code you need:
fields = dsc.fields
    agreementID = rowYesterday[fieldnamesYesterday.index("AGMID")]
    datetimeVal = rowYesterday[fieldnamesYesterday.index("DIGIDATE")]
    print agreementID
    print datetimeVal
