Error: Unable to load image" when displayng a cached layer"
2575
03-03-2016 08:22 AM
MichaelGinzburg
I started to get this error in browser log while displaying a cached service in a webmap.
Displaying service in ArcMap is OK.
The error comes from the service, the log says:
columnNumber:46
fileName:"http://myserver/arcgis/home/js/arcgisonline/arcgisonline.js"
lineNumber:3869
message:"Unable to load image: http://myserver/arcgis/rest/services/Ortho2015/MapServer/export?dpi=96&transparent=true&format=png32..."
stack:".cache["esri/layers/DynamicMapServiceLayer"]/</g<._onErrorHandler@http://myserver/arcgis/home/js/arcgisonline/arcgisonline.js:3869:46
.cache["dojo/_base/lang"]/</g.hitch/<@http://myserver/arcgis/home/js/jsapi/dojo/dojo.js:182:236"
Thanks for your help!
Michaek
MichaelGinzburg
Update: in a list of issues addressed in 10.3.1 I found following:
NIM102500 -
Default extent of basemaps are not honored when the coordinate system is other than WGS 1984 Web Mercator Auxiliary Sphere.
What exactly "are not honored" means? I use base maps both in WGS 1984 and Israel ITM projected coordinate systems. Can it be the issue?
Thanks!
