Adding a shapefile to a blank .mxd in Arcpy
5904
5
02-29-2016 01:37 PM
johnrogers4
How can you add several shapefiles to a blank .mxd using a script written with Arcpy? I've started with the code below. The code runs with no errors but the shapefile is not added to the blank .mxd. I'm not sure if you have to first convert the shapefiles to .lyr files? I am trying to run the script outside of ArcMap in command line window.
import arcpy
from arcpy import env
# get the map document
mxd
= arcpy.mapping.MapDocument("CURRENT")
# get the data frame
df
= arcpy.mapping.ListDataFrames(mxd,"*")[0]
# create a new layer
newlayer
= arcpy.mapping.Layer(path_to_shapefile_or_feature_class)
# add the layer to the map at the bottom of the TOC in data frame 0
arcpy
.mapping.AddLayer(df, newlayer,"BOTTOM")
JakeSkinner
Esri Esteemed Contributor
Hi John,
If you are running this code within ArcMap in the Python window, try adding the line:
arcpy.RefreshActiveView()
AravindatStoryMaps
Are you using (r'Path') or just ('Path) for "path_to_shapefile_or_feature_class"?
DarrenWiens2
Your code runs fine for me, referencing a shapefile. It adds the layer to the TOC.
newlayer = arcpy.mapping.Layer(r'C:\junk\points.shp')
Just make sure you're writing a proper Python path (like above).
johnrogers4
DarrenWiens2
In that case, I'm surprised that it knows what "CURRENT" is (not saying it can't be done, I've just never done it that way). Do you have better luck running MakeFeatureLayer​?
