AppStudio Player unable to edit features in .geodatabase ?
3414
02-28-2016 01:14 PM
TobiasFimpel1
Can anyone replicate this or suggest how to troubleshoot?
(1)The AppStudio Desktop Edition has an ESRI sample named "Local geodatabase editing". I can download that into AppStudio Dektop, run it from AppStudio Desktop by clicking the Run button in the top left, and everything works great.
(2)Then in AppStudio Desktop I "create a new app from Local geodatabae editing". Again I run it from AppStudio Desktop and again everything works great.
(3)Now I upload my app that I created in (2) to ArcGIS Online, open it in the AppStudio Player App, and I am unable to update features.
Any ideas? Is this a known limitation of AppStudio Player? (I observe the same behavior with other apps that don't just update features but also insert and delete features/records/attachments - editing operations work great in AppStudio Desktop but not in the Player App.)
Tobias
TobiasFimpel1
Answering my own question, maybe it helps somebody else in the future: this is licencing related. As defined here​​​ to do offline editing the app needs to be ​​licensed at the Standard level. Whether or not you're signed into the Player App with an account that has a Standard level license for AppStudio seems to be irrelevant (unfortunately).
In the case of the Local geodatabase editing sample, one way to make it work is like this:
//insert on  approx. line 27, after "App {":
    // Define Portal components
      Portal {
          url: "http://www.arcgis.com"
          onSignInComplete: {
              console.log(qsTr("Signed in!"));
              ArcGISRuntime.license.setLicense(portal.portalInfo.licenseInfo)
          onSignInError: {
              console.log(qsTr("Failed to sign in."));
//insert on approx. line 349, after "Component.onCompleted: {":
function portalSignIn ( ) {
      // Supply user credentials to login into online Portal
      portal.credentials.userName = "<your username>" //the username here
      portal.credentials.password =  "<your password>" //the password here
      portal.signIn();
    portalSignIn();
TobiasFimpel1
      Portal {
          onSignInComplete: {
          onSignInError: {
      portal.signIn();
    portalSignIn();
