Error - Advanced ArcMap Settings
4286
02-27-2016 12:22 PM
geogeo
I am trying to run the utility of "advanced arcmap settings" and I am not able to run it, I am getting this error "you are not licensed to run this product", how I can solve it? I am using 10.3 Esri Desktop Instructors
DanPatterson_Retired
are you logged in as administrator on your machine?
Addendum or run it like this
Close all ArcGIS applications.
1) In Windows explorer, Go to C:\Program Files (x86)\ArcGIS\Desktop10.2\Utilities
2) Right-click AdvancedArcMapSettings.exe > Run as administrator.
from https://community.esri.com/message/521126#comment-521126
JorgeGonzalez2
This also works when you try to get rid of license expiry notifications  within ArcMap Advanced Settings Utility and get the following message: 'You must run this application as Administrator to change this key'. Thank you Dan!
JayantaPoddar
The above utility checks for valid ArcGIS for Desktop license. It seems the ArcGIS Administrator cannot retrieve any license or the license has expired. Can you open ArcMap? If not, check the licenses in ArcGIS Administrator/License Server Manager.
Think Location
