Get available paths between selected points/Features
3027
02-24-2016 09:45 PM
Raghunatha_ReddySura
I am new to the arcgis and web portal development, how to get the available paths(all) between two selected points/features? Is there is any widget is there that will cater this requirement, or any customization required to do this.
Raghu.
AbhishekRathi1
Dear Raghunatha
You can check in attribute table.
if you want to calculate distance their is a tool name point distance in proximity toolset in Analysis tools.
RobertScheitlin__GISP
Raghunatha,
   You can use the Closet Facility widget for that:
Closest Facility Widget for Web AppBuilder
Thanks, But in my case, I have source and destination points. I need to find out the available/possible paths between those points only.
LubnaMansour
You can use the ready widget ..
It is very simple
