Linking data from ASCII to Raster
2039
02-18-2016 05:34 AM
SamuelLacey
Trying to open a map document on another computer I get the red ! error of the data not being linked correctly. I have repathed most of the data back which is fine, however I have hit a problem trying to repath a large amount of temperature data. In the ArcMap file originally data was added by conversion of ASCII to Raster. However when I try to 'Repair data source', I can map back to the original ASCII file, however this wont work as it is looking for a Raster.
Is there anyway of mapping back and converting all in one step? As going back and adding each ASCII as a Raster individually will take a very, very long time.
Thank you in advance, and I hope i've made it as clear as possible to understand what i'm struggling with.
DanPatterson_Retired
Not that I have seen, I suspect the rasters ... if they were esri grids... are located elsewhere and not necessarily in the path you think they are in.
