TOC coding problem
3123
02-15-2016 07:36 AM
Muqit_Zoarder
Dear all, please have a look on my TOC (table of content) coding. I have placed the agsjs folder in my web root directory and the path is all rgiht i think. But I am not getting any result.
Script:
<!DOCTYPE html>
<html>
<head>
        <meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
        <meta http-equiv="X-UA-Compatible" content="IE=Edge" />
        <meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no">
        <title>Dresden Building Web Map</title>
        <link rel="stylesheet" href="http://js.arcgis.com/3.15/esri/css/esri.css">
        <link rel="stylesheet" href="https://js.arcgis.com/3.15/dijit/themes/claro/claro.css">
   <link rel="stylesheet" type="text/css" href="./agsjs/css/agsjs.css" />
      <link rel="stylesheet"  href="./css/toc.css">
        <script type="text/javascript">
        var dojoConfig =
        {paths: {agsjs: location.pathname.replace(/\/[^/]+$/, '') + '/agsjs' }};
        </script>
    <script src="http://js.arcgis.com/3.15/"> </script>
    <script>
      var map, toc, dynaLayer1;
      require(["dojo/_base/connect",
             "dojo/dom", "dojo/parser","dojo/on", "dojo/_base/Color",
             "esri/map",
             "esri/geometry/Extent",
             "esri/layers/FeatureLayer",
             "esri/layers/ArcGISTiledMapServiceLayer",
             "esri/layers/ArcGISDynamicMapServiceLayer",
             "esri/symbols/SimpleFillSymbol",
             "esri/renderers/ClassBreaksRenderer",
             "agsjs/dijit/TOC",
             "dijit/layout/BorderContainer",
             "dijit/layout/ContentPane",
             "dojo/fx", "dojo/domReady!"], function(connect,  dom, parser, on,Color,
             Map, Extent, FeatureLayer, ArcGISTiledMapServiceLayer, ArcGISDynamicMapServiceLayer,
             SimpleFillSymbol,ClassBreaksRenderer,
             TOC){
              // call the parser to create the dijit layout dijits
              parser.parse(); // note djConfig.parseOnLoad = false;
              map = new Map("map", {
                basemap: "topo",
                center: [-85.75, 38.25],
                zoom: 13
              dynaLayer1 = new ArcGISDynamicMapServiceLayer("http://192.168.224.16:6080/arcgis/rest/services/Dresden/MapServer", {
                opacity: 0.8
            map.on('layers-add-result', function(evt){
            toc = new TOC({
                    map: map,
                    layerInfos: [{
                      layer: dynaLayer1,
                      title: "DynamicMapServiceLayer1"
                      //collapsed: false, // whether this root layer should be collapsed initially, default false.
                      //slider: false // whether to display a transparency slider.
                  }, 'tocDiv');
                  toc.startup();
                  map.addLayers([dynaLayer1]);
  </head>
   <body class="claro">
        <div id="content" data-dojo-type="dijit/layout/BorderContainer" design="headline" gutters="true" style="width: 100%; height: 100%; margin: 0;">
            <div data-dojo-type="dijit/layout/ContentPane" id="leftPane" region="left" splitter="true">
                <div id="tocDiv">
                </div>
            </div>
            <div id="map" data-dojo-type="dijit/layout/ContentPane" region="center">
            </div>
        </div>
    </body>
</html>
Tags (1)
LuciHawkins
Hey Muquit,
I believe you are missing a   .    in the two lines below.  Should be:     "../agsjs......
<link rel="stylesheet" type="text/css" href="../agsjs/css/agsjs.css" />
      <link rel="stylesheet"  href="../css/toc.css">
Luci
Muqit_Zoarder
Dear all, thanks for your quick response, actually I have found one big mistake that I have done. I did not close the script before the </head> tag. It should be a </script>. Now its working.
Muqit
RobertScheitlin__GISP
Muqit,
  Here is what I have working with the agsjs folder being locally on the same directory as the application.
<!DOCTYPE html>
<html>
<head>
  <link rel="stylesheet" type="text/css" href="agsjs/css/agsjs.css" />
  <link rel="stylesheet" href="agsjs/dijit/css/toc.css">
    var dojoConfig = {
      paths: {
        agsjs: location.pathname.replace(/\/[^/]+$/, '') + '/agsjs/'
  </script>
  <link rel="stylesheet" href="https://js.arcgis.com/3.15/esri/css/esri.css">
  <link rel="stylesheet" href="http://js.arcgis.com/3.15/dijit/themes/claro/claro.css">
  <style>
    html,
    body {
      height: 100%;
      width: 100%;
      margin: 0;
      padding: 0;
    #map {
      height: 100%;
      margin: 0;
      padding: 0;
  </style>
  <script src="https://js.arcgis.com/3.15/"></script>
  <script>
    require([
        "dojo/dom", "dojo/parser", "dojo/on", "dojo/_base/Color",
        "esri/map",
        "agsjs/dijit/TOC",
        "dojo/domReady!"
      ], function (
      dom, parser, on, Color,
      SimpleFillSymbol, ClassBreaksRenderer,
      TOC) {
      parser.parse();
      map = new Map("mapDiv", {
        basemap: "topo",
        zoom: 8
      dynaLayer1 = new ArcGISDynamicMapServiceLayer("http://sampleserver6.arcgisonline.com/arcgis/rest/services/Census/MapServer", {
        opacity: 0.8
      map.on('layers-add-result', function (evt) {
        toc = new TOC({
          map: map,
          layerInfos: [{
            layer: dynaLayer1,
        }, 'tocDiv');
        toc.startup();
  </script>
</head>
  <div data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline'" style="width:100%;height:100%;margin:0;">
    <div data-dojo-type="dijit/layout/ContentPane" id="leftPane" region="left" splitter="true" style="width:275px">
      <div id="tocDiv">
      </div>
    </div>
    <div id="mapDiv"
         data-dojo-props="region:'center'"
         style="padding:0;"></div>
  </div>
</body>
</html>
