Can Runtime .NET use existing ArcGIS License?
2886
02-12-2016 07:50 PM
JosephSaltenberger
Can an ArcGIS Runtime .NET application use existing concurrent or single use licenses, similar to ArcEngine?
Tags (1)
JosephSaltenberger
I've gone through the documentation. I assume the answer to my question is No, since they are using different technologies, but I'll ask again with some additional detail:
Can an ArcGIS Runtime .NET application use existing concurrent or single use licenses, similar to ArcEngine? For example, if I deploy a runtime application to a user that has ArcGIS for Dekstop installed on their machine, can they use the application without additional costs incurring?
Thanks.
YueWu1
by Esri Regular Contributor
Hi Joseph,
You need register a developer account for the first step. Here is the documentation about License your app—ArcGIS Runtime SDK for .NET | ArcGIS for Developers
JosephSaltenberger
Thanks.
EricBader
Honored Contributor
Hi Joseph,
You're hunch is correct. No, there isn't concurrent licensing for Runtime apps, nor is there a way to leverage your Desktop license like you were able to do with Engine. As you correctly stated, these are different products and technologies.
Great question. Thanks.
